Degree to degree,minutes,seconds conversion
I need to convert degree to degree, minutes and seconds. Example: 1degree=1degree,0minutes,0seconds.
The front panel should have one numerical control and one numerical indicator.
(4,509 Views)
Settings units and using relative time formatting you can get a convenient control/display for degrees (see attachment).
LabVIEW, C'est LabVIEW
(4,509 Views)
Multiply your control value by 3600 (sec/degree) and wire the product to the
indicator. Right click on the indicator and select "properties"; then select
"format and precision" and select "relative time". Make sure the hh:mm:ss
radio button is selected. If you input 1.5, you will get 1:30:00.
TeeJay
"LabVIEWnewstudent" wrote in message
news:50650000000800000030F40000-1079395200000@exchange.ni.com...
> indicator.
(4,509 Views)
