First, you can you use the property nodes invocing the cursors using the menu item "active cursor" and setting it to 0 and another one to 1. And setting those both active. Second, you can click rigth on the graph on the front panel getting the contect menu. From there you go the "visible items" setting the menu item "Cursor legend" on. Then you will see the cursor legend at the bootom of the graph which is still gray and inactive. Now click at the legend at position of the "move" crosses this should activate the cursor and repeat that for the second one.
