Defining a Region of Interest on a Live Image
Hey all,
I am writing an application where I need the used to be able to draw a rectangular region of interest on a "constantly" updating (~5 frames per second) image.  Once they get the box into the region they want they will push a button to record the coordinates and size of the ROI.
I am running 8.2 full, no vision package.  Any suggestions?
My first thought was to use cursors to define the corners of the box, but my end-user wanted something simpler...
Thanks all.
Matt
(2,818 Views)
Hi Matt,
how do you get the image? Where do you show it?
Mike
(2,801 Views)
Mike,
The image comes from a CCD camera, it is grabbed an turned into a 2-D array using subvi's provided in the manufacturers software developmen t kit.  I display it on the front panel in an intensity graph.
Matt
(2,789 Views)
Hi Matt,
you can use the cursors or you use the "Mouse Move" Event to get the position and store it with a key press event into a shift register.
Hope it helps.
Mike
Message Edited by MikeS81 on 07-08-2008 09:04 PM
(2,777 Views)
