Defining Modbus Address on PXIe
Any direction or help appreciated on this question. If I define analog input address for each channel as 303000, 303002 and 303004 on Master modbus driver.
Do I have to define same address on PXIe(Slave) channel side? either in configuration file or through NI Max. In this case I am using NI PXIe 4300.
(3,136 Views)
Are you using LabVIEW for the master and the slave applications? If so, Are you using the Modbus Library or the Modbus I/O server
(3,081 Views)
Hi Donh,
No, we are using our in house developed Modbus driver as master and NI PXI act as slave. As showed below we define addresses on  master side, but not sure do I need to define same addresses on slave side.
(3,076 Views)
