Defective Control
If I use a system string control , I cannot doulbe click it to goto the block diagram. Classic and Modern work OK.
The system numeric controls works OK.
LV 8.2
Message 1 of 9
(7,249 Views)
All I can say is that I see the same behavior as you with your VI.
Also using LV 8.2.
Message 2 of 9
(7,230 Views)
Hello!
This was reported to R&D (# 45bc50k8) for further investigation. A possible workaround for this is to not use the auto tool, which automatically selects a tool for you, based on your location in LabVIEW.  If you use the "Position/Size/Select" tool (aka, the arrow), you can double-click on the system string control and be routed to its location on the block diagram.  Thanks for the feedback!
Have a great weekend!
Janell R | Applications Engineer
Message 3 of 9
(7,203 Views)
Additional info on system controls.
See attachemnt.
I added System numeric 2 and system numeric 3.
System numeric 2 under visable items does not give a selection for increment / decrement if you go into properties and check the box the increment / decrement  still does not work.
Ststem numeric 3 was made from a system control but I went to the block diagram and changed it to a constant then back to a control, increment / decrement is now selectable, however the control apears to have been changed to a modern control. This is on an 8.2.1 machine. I did the same thing on an 8.20 machine and the control was still a system control.
Win XP pro (sp2)
LV8.2.1 and 8.20
Message 4 of 9
(7,064 Views)
System String control behaves the same even in 8.5. Smiley Surprised
I think it is NOT still fixed. Smiley Indifferent
- Partha ( CLD until Oct 2027 🙂 )
Message 5 of 9
(6,774 Views)
The system numeric is not supposed to have increment/decrement buttons so I would consider it a bug that the properties page doesn't have this option greyed out. If you want increment/decrement buttons, you have to use the system spin control.
Message 6 of 9
(6,750 Views)
Hello!
This was reported to R&D (# 4EBG6JAH) for further investigation.
Message 7 of 9
(6,726 Views)
8.2.1 behaviour is reflected in 8.5 also.
Dennis, so wats the basic diff between system numeric & system spin controls ?
Brian, will the bug report cover all of the defects or only the changed behaviour in the latest version. Please do clarify.
Message 8 of 9
(6,702 Views)
But the simplest work-around would be to Rt click -->> Find Terminal. Smiley Wink
Message 9 of 9
(6,701 Views)
