Default font
I once switched the font to Symbol so I could use some Greek letters on my front panel and now every new control I create has a label appearing in the Symbol font. Block diagram comments show up normally. How do I fix this annoyance?
Message 1 of 12
(8,556 Views)
Accepted by JohannJunginger
CTRL+1 should bring it back to the default Application Font.
Redhawk
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
Message 2 of 12
(8,552 Views)
It is not clear what you did. Did you (1) change the font of any particular text element or did you (2) change the default font in the options menu? Only (2) should have the effect that you see.
Message 3 of 12
(8,542 Views)
I had typed the character in the Application(?) font and selected the character and changed it to Symbol on the FP. If I could find where to change it in options my problem would be solved.
Message 4 of 12
(8,527 Views)
Tools... > Options > Environment > Fonts might be what you are looking for. I myself am confused now as well.
Redhawk
Message 5 of 12
(8,514 Views)
So in my Environment Options it shows Application Font*, Dialog Font* and System Font*. I don't see an option for changing Current Font. I though it found it in LabVIEW.ini as a FPFont="Symbol" 15 but changing that didn't seem to have an effect unless I mangled the syntax.
Message 6 of 12
(8,505 Views)
The option for changing current font is at the top of the FP. If you fully restart LabVIEW, you're seeing Symbol font here?
Spoiler
Redhawk
Message 7 of 12
(8,499 Views)
There are symbolic font and adapt to the OS theme. Could it be that you have Greek localized windows?
That would do it! Have you tried to just delete that line? I am not sure if you have to restart LabVIEW after changing that line.
Message 8 of 12
(8,497 Views)
That is correct. It shows up as Symbol on LabVIEW restart and even full PC reboot. All my other Windows apps default to 'regular' characters.
Message 9 of 12
(8,491 Views)
Deleting the line in the LabVIEW INI file solved the problem. I did restart LabVIEW but I thought that was standard practice whenever you mess with the INI file. I had forgotten there are many hidden options in the INI file that you cannot get from Tools --> Options.
Message 10 of 12
(8,484 Views)
