Decoration is missing in LV NXG web module
I want to decorate my web page with lines shapes and text etc, but the function is inactive in the NXG web module. Only the URL Image function is possible.
If not possible, how else can I get the website decorated with lines, text, etc.?
Message 1 of 11
(3,750 Views)
Yes, I also didn't see decorations on "Drawings" pallet. It seems that we cannot use those items.
As other method, I drew a circle with HTML + CSS.
Certified LabVIEW Developer
GCentral
Message 2 of 11
(3,739 Views)
Thank you for your feedback. Unfortunately I am not familiar with HTML and CSS, do you have any examples of how to program lines, circles and text
Message 3 of 11
(3,701 Views)
Why don't you look for on google with "HTML CSS circle" word?
For example I found below.
How To Create Circles / Round Dots https://www.w3schools.com/howto/howto_css_circles.asp
GCentral
Message 4 of 11
(3,699 Views)
Thanks, sorry, I just started google this. I see there are many examples. Can't HTML programming, but will try to teach me so that I can style my web page with some lines and text, etc
Message 5 of 11
(3,694 Views)
Also thought I could use a layout created in ACAD (see example attached) and import it in to *.gviweb as a JPG image, but even though the image is 5 MB it is imported with very low resolution so text and lines get very diffuse. Do you know how to import at higher resolution?
Message 6 of 11
(3,692 Views)
Advantages of LabVIEW NXG Web Module is we can write the code with HTML/CSS/Javascript.
I cannot understand why are you going to use NXG Web Module. Your application isn't satisfied with non web application?
For example, following steps would satisfy your requirement. You can draw circle with boolean button.
  1. Place boolean button on panel with HTML class attribute name.
  2. Edit HTML source and CSS following this instruction -> How To Create Round Buttons
GCentral
Message 7 of 11
(3,691 Views)
Why don't you import your image with HTML <img> tag?
GCentral
Message 8 of 11
(3,689 Views)
Attached application is just one example. Will today read me up on CSS and try to create a similar layout using this functionality
Message 9 of 11
(3,683 Views)
Do you do this with creating an HTML code? Could you please explain how I do this
Message 10 of 11
(3,681 Views)
