Deconstructing a 2D Array with a Loop
I'am generating via a .NET function an Output in the form of a 2D Array:
Object[][]
Now i'm funneling this towards a For-Loop, in the hopes of turning this Output by means of auto-indexing into sequential chunks of
Object[]
as i have a function within the loop that is expecting "Object[]" as an argument.
Now im getting the error in the pic related: LabView "chunks" my 2D Array in a different format and i cannot connect them anymore.
How do i need to adjust the code so that i can connect ?
(2,808 Views)
The problem does not appear to be with the auto-indexing of your array but rather with the datatype that you provide (or try to use) of the elements in the array.
Since you do not provide more information, I cannot help you more than that. Try to provide actual code in the simplest form possible that reproduce your problem.
Marc Dubois
(2,781 Views)
That doesn't appear to be a 2D array. The function returns a 1D array, and the autoindexing turns it into a scalar.
(2,713 Views)
