Decimal to hex convert
sorry but i have a simple question. I want to convert decimal number 0-10000 (like 10000 (decimal) to 27 and 10 (hex) or 1000 (decimal) to  03 and E8 (hex)) to two hex numbers and back. Iám searching for an easy way.
I tried different ways but i can`t find a solution.
greetings Schwede
Message Edited by Schwede on 12-10-2008 07:11 AM
Message 1 of 9
(6,378 Views)
Just use the "Number to Hexadecimal String" function and then split the string in half.
Message 2 of 9
(6,375 Views)
Thankyou,
but i don`t want to have a string i need numbers to put them in a byte array.
greeting Schwede
Message 3 of 9
(6,372 Views)
Accepted by topic author Schwede
Message 4 of 9
(6,368 Views)
That`s great, but didn`t help. The result are two decimal numbers. And i need two hex numbers that i can put in a byte array. This byte array i give over to teststand.
Message 5 of 9
(6,341 Views)
Schwede,
please see attached VI. If you need different amount of Bytes, please modify the "Bytes" constant for the second for loop.
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 6 of 9
(6,324 Views)
A very quick an easy method. For numbers go to palette numeric>>data manipulation>>join numbers and split numbers
Message Edited by t06afre on 12-10-2008 07:59 AM
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 7 of 9
(6,306 Views)
Thankyou Norbert,
but the solution comes from Pnt (yours and t06afres is fine, too).
I don`t think about that the numbers are converted automatically. Now it works fine.
Schwede
Message 8 of 9
(6,291 Views)
Use the Split Number and Join Number
Omar
Message 9 of 9
(6,289 Views)
