Decal Custom Control
You have two things that you can edit here. The triangle and the background. You only want to edit the triangle.
You need to be a bit of a graphic artist if you want nice custom controls see some of mine.
These are for a new controler that I am making. I made every part of it and I still program. I like both the challenge of working out the problem and making it pretty.
Tim
GHSP
Message 11 of 25
(6,461 Views)
Here is the whole panel layout. It is all touch screen. What do you think?
Tim
GHSP
Message 12 of 25
(6,458 Views)
Accepted by ASTDan
Found a solution.
Downloaded an Icon from Icon Finder that lools similar
http://www.iconfinder.com/icondetails/1825/32/play_player_icon?r=1
Modified it in Paint, then imported as decal.
Thanks for all your help!
Dan Shangraw, P.E.
Message 13 of 25
(6,452 Views)
Hello Tim,
The amount of work that I am assuming you put in to make all those icons makes me tired...
Looks great!  I don't have the talent, patience, or time to even attempt that.
I just try to use what is out in the community and modify it slightly.
http://decibel.ni.com/content/groups/ui
Dan Shangraw, P.E.
Message 14 of 25
(6,449 Views)
I think you owe the community a nugget!
WOW
"Should be" isn't "Is" -Jay
Message 15 of 25
(6,440 Views)
WOW
Thank you,
I never thought about doing a nugget. I will see if I can put something together. What would you like the nugget to include?
Tim
GHSP
Message 16 of 25
(6,427 Views)
WOW
Thank you,
Dan-
Appologies for going off your topic! I won't hijack your thread for more than 1 post.
Tim-
I encourage you to visit the hearding cats thread
IMHO the help for customizing controls is vague on how to select and edit the various control elements-  very little is discussed on the diferences between picture elements (or even that for a boolean the 6 elements are Inactive, Active T, F T-F and F-T I guess from your solution)  Text, Glyphs, etc or how to add new elements to a control.  You seem to have found out from experience some of the less robustly documented concepts of customizing controls.
So, a nugget on what to edit, why that element, with what tools? Add key GA concepts that guide your development process. and you'll have a dummy's guide to great controls that would benefit us poor slobs just "slugging through it as we go."
Message 17 of 25
(6,415 Views)
This thread is missing a lot of Kudos.
Richard
Message 18 of 25
(6,408 Views)
Hello Jeff,
I like where the conversation went.  Hijack away!
I didn't know anybody could do a nugget.  Could you explain that a little more.
Dan
Dan Shangraw, P.E.
Message 19 of 25
(6,397 Views)
Read through the thread I linked earlier-  Smiley Wink
Message 20 of 25
(6,392 Views)
