Debugging on Mac
hi all,
I am trying to debug a MacOS Framework (in Windows, this is like a DLL). On a WindowsPC, I compiled my C++-Code into a DLL (debug on) and then chose LabView in Microsoft Visual C++ to connect to LabView and debug my DLL (which is called by a LabView-VI). This worked perfectly for me. Now trying to do the same with mac. Created a framework (debug on), chose LabView as Application and run it... but with MacOS (using XCode and GDB as debugger), it doesn't work. The breakpoints defined in my XCode-Code are found by GDB, if a breakpoint is hit, LabView waits and doesn't continue with the LV-Code. But I get a GDB-Error: Previous frame inner to this frame (could not unwind past this frame). Can't get any access to local variables in C++, so I can't really debug my code. The only solution is to switch back to Windows to find errors - but that's very annoying. Somebody can explain this error message or tell me where to look for a fault / tell me what to do?
Thanks in advance
Christian
THINK G!! 😉
Using LabView 2010 and 2011 on Mac and Win
Programming in Microsoft Visual C++ (Win), XCode (Mac)
(3,094 Views)
Hi Christian, is it possible for you to publish here the DLL and the Framework? It would help to try to reproduce the issue Best regards. Andrea P.
(3,019 Views)
Hi Christian,
This can occur  when you don't have enough stack frames between the current frame and gencode. Try setting the breakpoint a couple of lines deeper or a couple of functions deeper in the code - not on the top level function. Please post if this makes a difference.
Will
CLA, CLED, CTD, CPI
LabVIEW Champion
Choose Movement Consulting
choose-mc.com
(3,003 Views)
