DateTime String array in Graph
Greetings.
I tried to plot DateTime string array VS Numbers array with no success in the XY Graph object.
I even converted the DateTime string array to DateTime type using the VI called "Convert_String_to_TimeStamp.vi" with also no success as the X (Time) is just very big numbers and a datetime format.
Please check the attached shot, it will describe the situation clearly.
Thanks in advance
Ayman
Ayman Mohammad Metwally
Automation Engineer
Egypt - Cairo
Message 1 of 11
(6,713 Views)
are you tring to do this in real time? Do you have a copy of the data that you are trying to plot?
Tim
GHSP
Message 2 of 11
(6,707 Views)
The data is loaded from a txt file.
Automation Engineer
Egypt - Cairo
Message 3 of 11
(6,700 Views)
You need to set the display format for the X-axis to be time rather than a number or automatic format.  Right click on the graph and go to properties.  Go to the Display format tab.
Message 4 of 11
(6,697 Views)
Accepted by Ayman_Metwally
You have the data correct just not the display format for the time axis!
Just open the property wizard for the graph and select Display format- x axis and set up however you want to show the display.
Edit- Yeah what Raven's fan said!
"Should be" isn't "Is" -Jay
Message 5 of 11
(6,695 Views)
Perfect ... Many thanks
Automation Engineer
Egypt - Cairo
Message 6 of 11
(6,688 Views)
Oops ... Sorry I overlooked your reply ...
Thanks a million,
Automation Engineer
Egypt - Cairo
Message 7 of 11
(6,682 Views)
Does anyone know a quick way to convert a string array in Time format to a timestamp without having to put the whole format through a for loop (I have 1.2 million samples each time) and its taking a while. Does anyone know a quick algorithm or something similar to speed it up?
String is in the following format  00:00:00.726     and I have also have the date string available eg.   01/03/2011  but has to be a string as I am geting it from a txt file.
Any help would be appreciated.
Thanks 🙂
Message 8 of 11
(6,517 Views)
You could read the file line by line and use the scan from sting function to convert to a timestamp.
Message 9 of 11
(6,509 Views)
Thank you for the quick response, what you have there is what I am already doing, I was just wandering if there was a way to convert a full array at a time?
What you are proposing still means I have to do it line by line which takes time, I have an array of 1,000,000 items and just want to avoid doing them line by line or in a single for loop etc.
Just wandering if it was possible?
Peter
Message 10 of 11
(6,498 Views)
