Datasocket Problem
Okay, now I attached the files..
aj
Message 11 of 14
(1,226 Views)
Hello –
Are you running the DataSocket Server on the same computer or on a remote computer? If you are running the server on a remote computer, does running it on the same computer fix the problem?
Are the two computers on the same subnet? If not, does configuring them to be in the same subnet fix the problem?
Something to remember is that every time you make changes to the Data Socket Server Manager (add groups, permissions, etc.), you must restart the DataSocket Server for the changes to take effect.
SVences
Applications Engineer
Message 12 of 14
(1,045 Views)
When you predefine data item with the server manager, you have to check a check box allowing more than one writers to the data item. Without that, your client can't work, because your server monitor vi claims that writer control. Since you seem to not predefine a data item on the server, you would have to use vi server or property nodes to allow multiple writers. I haven't yet looked for such property nodes, but I do remember that datasocket has very few methods and properties you can control. Basicly thay want you to predefine your data item.
hope it helps,
aartjan
Message 13 of 14
(1,038 Views)
I checked and found no methods for datasocket and some properties for retreiving buffer sizes and URL etc. No way to programatically configure a data item.
aartjan
Message 14 of 14
(1,035 Views)
