Database memory leak
Hi All,
I had similar problem of memory I have modified Rec Fetch Recordset Data (R).vi (DB Tool Fetch Recordset Dat.vi) as shown and now my code use 3 times less memory and has faster response.
PBP
Labview 6.1 - 2019
Message 21 of 24
(1,696 Views)
CAR 321353 discussed in this thread has been fixed in LabVIEW 2013. For a more complete list of bugs fixed in LabVIEW 2013, check the LabVIEW 2013 Bug Fixes. You can download an evaluation copy of LabVIEW 2013 at http://www.ni.com/trylabview/ or if you have an earlier version of LabVIEW installed and an active SSP subscription, you will be able to download the latest version of LabVIEW through NI Update Service.
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments
Message 22 of 24
(1,514 Views)
I'm having similar problems with the database connectivity toolkit under LV 2013SP1 f2. I'm looking, at the following link: http://www.ni.com/white-paper/14541/ (LabVIEW Bug Fixes) posted by Jeff-P, but I'm not able to find the CAR ID 321353.
Is  the CAR been solved?
Thank you,
Paolo.
Message 23 of 24
(1,257 Views)
Adding onto a 3 year old thread can be a problem because people see a large number of responses and won't look for new posts. You should start a new thread and reference is discussion. But having said that, there is an alternative to the DCT that is much more efficient. Check here. The discussion is good, and the drivers in a current version are available on the last page.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 24 of 24
(1,222 Views)
