Database in CompactRIO
Hi, I'm doing a project which is made a database in a CompactRIO to save some data like alarms, analogic signals that receives the device. It was a project where started 1 year ago and the person who was responsible about the project achieved some things using PostgreSQL in a CompactRIO 9030, however the result wasn't excellent or what was expected because it was very volatile.
I got two options to do this project: SQLite and Database Toolkit Connectivity. But I don't which I need to pick to achieve the best result.
(4,516 Views)
The database connectivity toolkit is not an option. It uses Windows calls (ADO) and will not run on a cRIO running NI Linux Real-Time. SQlite might be a good option. You just need the SQlite-DLL for it to run, so you have to compile SQlite for this specific target, perhaps you can use an already existing DLL for Linux & x86-architecture.
Regards, Jens
Kudos are welcome...
(4,505 Views)
If I have a Library in LabVIEW that use SQLite, which was created by LVS-Tools, I could use that library in CompactRIO and run it in NI Linux  Real-Time?
(4,493 Views)
I'll attached a picture about LVS-Tools Library
(4,491 Views)
I'm not familiar with this library. If it uses the sqlite3.dll directly without any wrapper, it could be that this library will work on an cRIO. BUT: You still have to use a sqlite-Linux-x86 SO library.
Jens
(4,447 Views)
Where can I find sqlite-Linux-x86 SO library? And other thing if I create a .dll for my database, how do I use that format in CompactRIO? Because .dll is not compatible in Linux so I would have to install a emulator in CompactRIO to do that and i don't if it is possible
(4,426 Views)
Did you ever get to work? did you need to install software on the RIO to get this library to work?
(4,121 Views)
