Database error
While executing the program in debug mode, i could able to communicate to the database and retrirve the data, but when i build the application and run the same program I am getting the following error,
"Exception occured in Microsoft OLE DB provider forODBC drivers :[ORACLE][ODBC Oracle Driver][Oracle OCI]
ORA-06413:connection not open in Connect.VI
Error code - 2147467259
Any idea what could be the reason for connection not getting opened?
(3,668 Views)
(3,647 Views)
Hey Christian_M
THis didn't help me, I have said that in debug mode program works perfectly fine, when i build executable and run the program, it doesnt work,
any other suggestions?
(3,636 Views)
Accepted by cancancanopen
I got the solution, The database on which I am working on is of ver 1.0.1 i think, I need to include SQL connect, SQL disconnect, Fetch Query results, SQl query VI's in always include section while building the application.
(3,622 Views)
