Database acess from cRIO
Hi ,
Can I acess database from cRIO and modify the same?
I have a system which generate data and store using MS SQL server 2008.
I need to read the data using LabVIEW which is deployed in cRIO.
Is it possible to read .xls or MS ACCESS file from cRIO?
Kindly reply..
(3,459 Views)
Looks like someone has done the database part.
http://decibel.ni.com/content/docs/DOC-10453
(3,438 Views)
Did you want to do database access and storage on the cRIO, or just use the cRIO to modify a database running on a hostPC?
I ask because I wanted to have a database running ON my cRIO, and thought this was possible seeing as the Database connectivity palet is available for use.
I then did a design on my PC with the intention of porting it to the cRio once I got it working.  When I did that, I found out the cRIO doesn't support database access, because it requires activex.
Not cool.  Although, I guess I shuold'nt have done my database design on the PC in the first place and I would've found this problem a little earlier.
Did you manage a work around?
(3,291 Views)
