01-18-2002 01:15 PM
01-18-2002 04:36 PM
01-18-2002 05:11 PM
01-21-2002 10:05 AM
04-09-2002 09:22 AM
03-04-2009 12:42 PM
03-04-2009 12:44 PM
Just FYI - the reason I ask is for some reason, a cal routine we have for 1102 cards and TC-2095s attached to an E-series card through an SCXI-1001 chassis suddenly isn't saving Cal constants. I suspect it may be NiDAQ 7.4.4 (we had no problems with LV 6.1 and NiDAQ 6.9.2) as that is the version I've started using in prep for a new release of our DAQ app being written in LV 8.6.
Erik
04-05-2011 07:24 AM
I have a similar setup. I would like to calibrate the thermocouple channel after simulating an accurate voltage using FLuke 714 in the channel on the terminal block. Which VI do you use in the library of files? How do you go about calibrating it? Can you do it on LV 5.1.1 and DAQ driver 6.8.1 running Windows ME? The subVI that I am using to convert voltage to thermocouple temperature is Convert Thermocouple Buffer.vi.
