Database Fetching Example
The 'Fetching Example.vi' in the Database connectivity toolkit will work in LabVIEW 8.2 but will not work in LabVIEW 8.5.
I get:
"Error 3005 occurred at Conn Execute.vi->Fetching Example.vi
Possible reason(s):
Automation Open: Object specified is not creatable in Conn Execute.vi->Fetching Example.vi"
We looked into this a little and found no difference between the two vi's and the error was originating from the Conn Execute.vi
If you have any insight, thanks in advance!
Nathan
(3,473 Views)
Hello
The issue that you are describing is actually a known issue with the toolkit that is document internally in our Corrective Action Request (CAR) # 66867.
Would you be able to let me know what version of the Toolkit you have by checking the version in Measurement & Automation Explorer (MAX)?
Also, do you have LabVIEW 8.5.1 available to you?
Have a great weekend!
Kameralina
(3,456 Views)
The version of the Database Connectivity Toolset is 1.0.132
I think I might be able to get LabVIEW 8.5.1, will it work in 8.5.1?
For now, Iim using the non-fetching method.
(3,449 Views)
Yes, please try this and let me know whether it works.
I was initially under the impression that it had to do with the version of the toolset, but I did see a mention of it maybe working with 8.5.1.  I can try this out at our end, but please feel free to use 8.5.1 in the meantime to test it.
Message Edited by FieldKam on 06-30-2008 06:22 PM
Kameralina
(3,422 Views)
