05-03-2013 01:45 PM
I am trying to programmaticaly by using databse connectivity toolkit add a column to a current table in a database.
i am using a file dsn and access 2007.
I can do just about anything but send an alter statmenet to accessd atabase to add a column
I am using the following syntax
ALTER TABLE mytable ADD COLUMN newcolumn NUMBER[NULL]
also tried this
they both give me an error saying syntax error. can someone provide me the right syntax to add a column to an existing table? I know microsoft access says it does not support ALTER commands. not sure if there is a workaround.
thanks,
sam
05-05-2013 03:47 AM
I don't think the problem is the ALTER TABLE statement, because Access can handle that. I think it's the NUMBER as a type you want to assign. It's too generic.
I think yo should use one of the following for numbers
06-06-2013 05:11 PM
Brjon,
sorry for the long time to read this message. I am still not able to get this working. I am trying to alter the table to add a numberic double number in a column. would you be able to provide me the syntax to do this? right now I tried the following and it is not working.
ALTER TABLE Frequencies ADD COLUMN 20-30000 NUMBER DOUBLE[NULL];
can you let me know where is my mistake on this?
many thanks in advance,
Sarkis
06-07-2013 05:53 PM
Hi ssherian,
From a quick search (since I am not too familiar with MS Access), is this what you are trying to do?
EXTERNAL Link: MS Access Alter Table Add Column
