Database Connectivity Microsoft Access Alter Table (Add column)
I am trying to programmaticaly by using databse connectivity toolkit add a column to a current table in a database.
i am using a file dsn and access 2007.
I can do just about anything but send an alter statmenet to accessd atabase to add a column
I am using the following syntax
ALTER TABLE mytable ADD COLUMN newcolumn NUMBER[NULL]
also tried this
they both give me an error saying syntax error.  can someone provide me the right syntax to add a column to an existing table? I know microsoft access says it does not support ALTER commands.  not sure if there is a workaround.
thanks,
sam
(4,575 Views)
I don't think the problem is the ALTER TABLE statement, because Access can handle that.  I think it's the NUMBER as a type you want to assign.  It's too generic.
I think yo should use one of the following for numbers
  • SHORT: This is for natural numbers, relatively large
  • INTINTEGER, and LONG: This is for (very large) natural numbers
  • SINGLE and REAL: This is for decimal numbers that do not need much precision
  • DOUBLE and NUMERIC: This is for decimal numbers that need precision
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
(4,522 Views)
Brjon,
sorry for the long time to read this message.  I am still not able to get this working. I am trying to alter the table to add a numberic double number in a column.  would you be able to provide me the syntax to do this?  right now I tried the following and it is not working.
ALTER TABLE Frequencies ADD COLUMN 20-30000 NUMBER DOUBLE[NULL];
can you let me know where is my mistake on this?
many thanks in advance,
Sarkis
(4,451 Views)
Hi ssherian,
From a quick search (since I am not too familiar with MS Access), is this what you are trying to do?
EXTERNAL Link: MS Access Alter Table Add Column
| Zach J. | Systems Engineer, HIL and Test Cells | National Instruments |
(4,434 Views)
