Database Connection Reference in While Loop
As shown in picture below, i have DB connection reference. "Connection properties 2" indicator shows proper values, but the same "Connection properties" indicator in while loop shows nothing, but connection numbers are the same (in probe). There is event structure in this while loop also if it matters. Why i can't get proper connection reference from while loop?
I'm using LV2011.
Kacper
Message 1 of 19
(6,683 Views)
Try putting a timeout, such as 100 ms, on the event structure (upper left corner icon). By default it is -1 (wait forever until event).
Message 2 of 19
(6,678 Views)
That's no problem. I fired this event (Results Button - Value Changed). This is strange problem - i attached next image.
When i run this VI, "connection properties 2" indicator shows proper values only in first loop iteration. After next iterations values are null. Maybe there is problem with ActiveX (ADO)? I'm using MySQL ODBC Unicode Driver.
Message 3 of 19
(6,668 Views)
You create a branch of the connection before the while loop and it disappears off screen.  I assume you take that over to a close connection where it gets closed.
aputman
Message 4 of 19
(6,658 Views)
I close connection at the end of application. There is only small part on images.
In addition - i have following error from 'DB Tools Get Properties' after first iteration.
NI_Database_API.lvlib:Conn Get Properties.vi->Controller.lvlib:Controller.lvclass:Actor Core.vi:1->Actor Framework.lvlib:Actor.lvclass:Actor.vi:7->Actor Framework.lvlib:Actor.lvclass:Actor.vi.ACBRProxyCaller.FC600014<ERR>ADO Error: 0x00000001
Property Node (arg 1) in NI_Database_API.lvlib:Conn Get Properties.vi->Controller.lvlib:Controller.lvclass:Actor Core.vi:1->Actor Framework.lvlib:Actor.lvclass:Actor.vi:3->Actor Framework.lvlib:Actor.lvclass:Actor.vi.ACBRProxyCaller.FC10001A
Message 5 of 19
(6,652 Views)
What you are calling "the end of the application" is not actually that.  You must understand dataflow.  Find some tutorials on this and you'll soon understand the problem.
aputman
Message 6 of 19
(6,647 Views)
You are getting this error because you are closing the connection before you realize.  These two sections of code are not the same.  The bottom one will give the error that you are getting.
aputman
Message 7 of 19
(6,640 Views)
@aputman It does not matter. It's reference to some point in memory. It should work this way until i close connection (by reference). Now i have error after first use of this reference and i think it's strange bahaviour.
Message 8 of 19
(6,636 Views)
What doesn't matter?  If i am misunderstanding something, you'll have to post some code because that is the obvious answer with what you have given us to work with.
aputman
Message 9 of 19
(6,632 Views)
It's not the dataflow.
This doesn't work too.
It's strange, because i can use this connection reference before the while loop. i'm getting records from DB before loop (not on this screenshot). Problem appears in while loop after first iteration.
Message 10 of 19
(6,630 Views)
