DataSocket
I get the following error:
"Error -2147467263 occurred at Nicht implementiert
 in DataSocket Select URL.vi->Browse To OPC Item.vi"
when using the shipped example "Browse To OPC Item.vi"
in LabView 2012 SP1 (64 bit)  (12.0.1f2).
Something missing ?
Mathias Hucke
(4,592 Views)
make sure that LabVIEW will not be blocked by the firewall. try to modify the following settings:
Configuring LabVIEW, LabVIEW DSC and Lookout to Work With the Windows Firewall
(4,562 Views)
Hey Mathias,
I can't find the example which you are using. It would be helpful for everybody, if you attach your code to this thread with a screenshot of the error message which you receive.
If you need the port and the protocol for the DataSocket, take a look in this document:
Configuring Software and Hardware Firewalls to Support National Instruments Products - Developer Zone - National Instruments
https://www.ni.com/en/support/security/configuring-software-and-hardware-firewalls-to-support-nation...
Stephan
(4,553 Views)
the firewall has been switched off completely.
The problem appears only under LV 2012 64-bit with all OPC examples.
On the other hand everything is working fine under LV 2012 32-bit.
I guess, I need (or better LabView needs) a 64 bit version of the
underlying datasocket libraries ... (?)
Mathias
(4,550 Views)
Hi Stephan,
the example is located under
NI Example Finder   =>  Communicating with external applications  =>   OLE for Process Control  =>   Browse to OPC item.vi.
see also the screenshots attached.
thanks,
Mathias
(4,546 Views)
Accepted by Mathias_Hucke
Hi Mathias,
I'm afraid that that will never happens
datasocket 64-bit - NI Discussion Forums
http://forums.ni.com/t5/LabWindows-CVI/datasocket-64-bit/m-p/1111622?requireLogin=False
(4,542 Views)
