DataSocket and Win NT?
Hi!
I've installed LabVIEW 5.1. Everything works fine when I try any of
the DataSocket-examples under Windows 95, but none when I use Windows
NT. I.e. the DataSocket server doesn't start on the NT-machine (I'm
logged in as an administrator).
Does anyone know what I do wrong?
/Mattias/
(2,907 Views)
mattias.ottosson_DELETE_THIS_@htu.se (Mattias) wrote:
>Hi!>>I've installed LabVIEW 5.1. Everything works fine when I try any of>the
DataSocket-examples under Windows 95, but none when I use Windows>NT. I.e.
the DataSocket server doesn't start on the NT-machine (I'm>logged in as an
administrator).>>Does anyone know what I do wrong?>Thanks>/Mattias/>
hi mattias
i've encountered this problem on two different machines with nt 4.0.
in both cases the datasocket-files
have not been installed in the default-directory (same for labview) and in
both
cases the registry-entries for the datasocket related files
"cwdss.exe" (server)and "cwdssmgr.exe"
(manager) have been wrong (wrong paths)!
i don't know if this is a bug or if something went wrong during installation.
hope
it helps you
bye
(2,907 Views)
