Data type conversion using Arduino Toolkit
Hello everyone,
I am just starting out with LabVIEW and the Arduino Toolkit. I have a problem sending desired output to the Arduino's digital pin. I have attached the VI to show what I have done so far and what I am trying to achieve.
The basic idea is that my setup brakes the sine signal into bunch of pulses and then I want to output this pulses to Arduino (version of PWM).
In the attached VI I have left the wrong connection as it is in order to show where I am stuck. The problem is converting/braking 1-D Array of word integers into single byte of integers. I might be doing something wrong in my setup and end up with the wrong data type.
I appreciate any input and help!
(3,132 Views)
Hi DESERT RACE,
We have a dedicated forum to LabVIEW and the Arduino Toolkit at www.ni.com/arduino.  I would recommend posting your question under the discussions tab there as you will likely get a much faster and more applicable response.
David
(3,117 Views)
Hi dbell0971, I figured out the solution myself. Actually it is Array realated Arduino was in the VI just to show where the output was going.
This thread can be closed or deleted.
(3,113 Views)
