Data missing from measurement file
Hiii, Cooljet
         Probably you are right you have to do so and i am also doing that thing, that we have to show it as a time we wnat but i m not sure that we should give it to the customer, because ultimately its a wrong solution which is out of customer specs, actually i also tried for the 10 ms cos in my case the signal was of 100 Hz, so we want 10 ms's time, but i couldn't achieve it, because of the limitation. by the where you are from?which country you belongs to?
Nishant
Message 21 of 21
(462 Views)
