Data input constraints (using shift registers)
@hurang wrote:
Data v2 is based on the 6th value.
In other words, if we receive a total of 10 pieces of data, data v1 is based on the first value, and data v2 is based on the 6th value.
Well, that would be easy to change. Have you tried?
Message 11 of 15
(515 Views)
Yes, I implemented the vi you helped me. it works well.
However, for data v2, changing to the 6th data standard has not been implemented yet....
Message 12 of 15
(507 Views)
You need to make your VI scalable and generic as a simple state machine. The code should be independent of the desired size of the arrays and should simply have an input for an array of sizes.
Message 13 of 15
(485 Views)
hello,
Do I need to create two shift registers containing NaN?
Or, do you operate a separate condition case for array data(data v1, data v2)?
I'm still trying, but honestly I'm not sure that I can do it...
Message 14 of 15
(465 Views)
Accepted by topic author hurang
You only need one shift register. You just fill it with the new reference value when the first element is added to the second array.
Message 15 of 15
(449 Views)
