Data acquisition from a web portal.
I'm planning to acquire data from a web portal to LabView to create a some mathematical calculations and produce some graph. I don't know which function to be used to acquire data. The portal is password protected. Can anyone help me out.
Kind Regards
Amal
(2,416 Views)
I am unsure if I understand the application correctly, Amal.
Do you mean having a system with some hardware that is acquiring data and controlling it from the web from a secured site?
If that's the case, I have used SystemLink Cloud for that purpose, where I will have a WebVI (built from LabVIEW NXG) hosted under a password in the SystemLink Cloud server, and control a device using the SystemLink Messages API.
Good luck in your project,
(2,352 Views)
Hello Oscar,
Sorry, I think you have been confused.
Actually i have some sensors that is been sending live measurement to a web portal which is password protected. I need to access that data using LabView and create a Labview control panel.
So is there any functions in LabView that i can used to acquire data from that portal.
Thank you
(2,327 Views)
Thanks for the clarification, Amal.
I believe you could explore the HTTP VIs, which allow you to send HTTP requests to a web service (or website). You can potentially send the credentials using the POST method and retrieve the information back by parsing the HTML response.
All the best,
(2,307 Views)
