Data Logging Issue with FPGA using CRIO. TDMS results attached.
I am having an issue with the attached LABVIEW project.
I am using Ni cRIO-9035. I would like to take a sample of 200 data points at a sample rate of Y (where, Y is less than the 40 MHz sampling rate of the cRIO). The samples would be taken 1 second apart and I would like to be able to specify via the GUI how many samples to take.
In general, the code seems to be working. The main issue, I am having is with the recorded data samples from the 6 analog channels. The values should be sinusoidal 60 Hz waveforms; however, looking at the results in the .tdms file it seems that maybe there is an underlying sinusoidal waveform; however, the data points are quite randomly distributed.
Perhaps I am logging the data points incorrectly? Any suggestions would be helpful.
Phil
(3,336 Views)
Which analog-in module are you using. Also the FPGA is able to run at 40 Mhz (or even faster), the analog-in module usually is not.
In addition it is recommended to use the "loop timer" in the first case of a flat sequence inside the FPGA code.
Regards, Jens
Kudos are welcome...
(3,321 Views)
Hi Jens. Thank you for the fast response.
I am using 2 x NI 9215. I would like to read the 200 measurements at a sampling rate above 8 kHz.
(3,316 Views)
Hi. I tried moving the loop count frame before the FIFO write frame as suggested. Unfortunately, still not working. Does anyone have any other suggestions?
I should note that the FIFO on the FPGA2.vi file is timing out.
Cheers,
Phil
(3,277 Views)
Bump.
(3,250 Views)
Hi Phil,
Do you get any errors during runtime? Has this project worked properly in the past?
Applications Engineering
(3,232 Views)
Hi Sailesh,
Project seems to run just fine. However, note the RT4 the "Timed Out?" indicator gets flagged at run-time.
I will send you a PM Sailesh.
Cheers,
Phil
(3,228 Views)
