02-09-2018 09:51 AM
So I created a VI in Labview 2017 and saved it under that system. Then I tried to open it in Labview 2015 but it gave me an error:
File version is later than the current Labview version.
An error occurred loading VI. Labview load error code 9: VI version (17.0) is newer than Labview version (15.0)
Is than any working arounds or upgrades regarding this issue?
Solved! Go to Solution.
02-09-2018 09:58 AM
Open it in your LabVIEW 2017 versions and do a File >> Save for Previous Version.
I'm kind of surprised your asking because you should've seen by now the Version Conversion forum. If you read the rules there and post your VI there, someone will convert it for you if you can't do it yourself.
02-09-2018 10:39 AM
Thanks! I'll keep that in mind. I've a tendency to just stay put in the main Labview Forum. I should branch out!
02-09-2018 10:45 AM
I should've said "you're", not "your".
Always go looking around. Sometimes you'll find some interesting stuff you would never have known existed until you stumble on it.![]()
