Data Comparison
Hello
I have simulated a sine wave using the 'simulate signal' block and stored ther resulting waveform as a TDMS file.
When I read the file and compare it with the generated sine wave of similar properties, I expect a constant true(LED) output.
Eventhough the probes show similar values under highlight, on comparison the 'equal' comparator does not give a consistent 'true' output.
(3,578 Views)
Have you tried comparing just the Y-values from the waveform? A waveform contains a t0 timestamp which will differ depending on when the waveform was started/saved so that might be why it's not showing as equal. Also, is there possibility in your code for the sine waves to become out of phase?
(blog)
(3,577 Views)
Also keep in mind that it is a real bad idea to compare floating point numbers by equal. You should compare the waveform to an envelope function.
Norbert
Norbert
Expert: Geometry
(3,571 Views)
Norbert - I agree with you (if you have data from two different sources - a DBL of 0 doesn't always equal (bitwise) another 0) but in this case I would have hoped that the sine wave function to generate exactly the same values in both cases (assuming the parameters are the same)
(blog)
(3,549 Views)
@Sam_Sharp wrote:
[...] (assuming the parameters are the same)
That might be true for this instance, yes, but we urge for generic solutions, do we? 😉
Norbert
Norbert
Expert: Geometry
(3,547 Views)
