06-03-2022 02:18 PM
Hello NI fellas,
I create a DAQ task sequence using virtual channels and wiring them in series.
My final purpose is to obtain 35 thermocouple signals and 4 current-type signals from the NI DAQ system.
my problem is like this,
when I wire 20 thermocouples and 4 current-type signals in series, I can obtain the data and write them in files.
However, When I append 15 more thermocuples right before the 20 thermcouples, there is no data sampling from DAQ.
When I only test 15 thermocouples, I can obtain the data from all of 15 channels.
I am wondering if there is an upper limit of virtual channel numbers wiring in series.
Best,
Ming
06-03-2022 03:43 PM
As far as I understand there shouldn't be an upper limit, there are numerous DAQ applications running with hundreds of sensor data acquisitions.
Please provide more details
06-03-2022 03:54 PM
Hello Santhosh,
I am using the NI-cDAQ-9174 with four slots of NI-sub modules.
There is no error reflected when I run the code.
I attach my labview design file for your review.The version I use is the Labview 2019 (19.0.1 32-bit).
Best,
Ming
06-03-2022 03:57 PM
Santhosh,
please find the attached file
