Data Acquiring from Mutiple Signal Channels
Hello NI fellas,
I create a DAQ task sequence using virtual channels and wiring them in series.
My final purpose is to obtain 35 thermocouple signals and 4 current-type signals from the NI DAQ system.
my problem is like this,
when I wire 20 thermocouples and 4 current-type signals in series, I can obtain the data and write them in files.
However, When I append 15 more thermocuples right before the 20 thermcouples, there is no data sampling from DAQ.
When I only test 15 thermocouples, I can obtain the data from all of 15 channels.
I am wondering if there is an upper limit of virtual channel numbers wiring in series.
Best,
Ming
(1,320 Views)
As far as I understand there shouldn't be an upper limit, there are numerous DAQ applications running with hundreds of sensor data acquisitions.
Please provide more details
  • What DAQs are you using?
  • Please attach the code you're using (if LabVIEW, share in LV2016)
  • What error do you get?
Santhosh
Soliton Technologies
(1,299 Views)
Hello Santhosh,
I am using the NI-cDAQ-9174 with four slots of NI-sub modules.
There is no error reflected when I run the code.
I attach my labview design file for your review.The version I use is the Labview 2019 (19.0.1 32-bit).
Best,
Ming
(1,293 Views)
Santhosh,
please find the attached file
(1,291 Views)
