Darren's Weekly Nugget 01/18/2010
One of my favorite enhancements to block diagram cleanup in LabVIEW 2009 is the ability to exclude parts of your diagram from all cleanup operations.  For example, I can right-click the case structure in the screenshot below and choose "Exclude from Diagram Cleanup" to keep its arrangement unaffected by all future diagram cleanup operations:
The exclude from cleanup feature can only be used on structures, so if there is a section of code that you want to keep clean, but it doesn't have a containing structure, then you can wrap it in a single-frame Flat Sequence Structure and then choose the cleanup exclusion option on that structure.
(4,517 Views)
I don't really like the workaround you mentioned, since it is possible that that single-pane flat sequence structure could change the timing of the code. That said, it's probably the best option out there.
Thanks for the nuggets - they're always tasty (and made with real white chicken meat)
-Randy
Nothing like a good dose of LabVIEW to cure what ails ya'.
(4,374 Views)
