Darren's Occasional Nugget 08/11/2008
Thanx for posting the screen shot of your block diagram darren.
Message 11 of 34
(8,546 Views)
> Off to the left of the diagram (not shown) is the private functionality I
was talking about.  Basically, I have to get all the Application
Instances where you might have VIs running...unfortunately, I don't think
there's a way to do this without private VI Server properties.
But if you are working one a project, there will only be VI's running in
your current application instances. So simply getting all VI's in memory
will do in most cases. At least it has been working for me. (I do a lot of
scripting, but never found the need to change my stop all VI).
Also, I simply stop all top level vi's. Guess it's a 'poor mans' solution.
(If I'd make my stop all VI more flexible, I'll never learn not to make VI's
modal untill testing is done.)
Another great use for VI's like this is to stop dynamic VI's started with VI
server.
Wiebe.
Message 12 of 34
(8,506 Views)
VI is going to come in VERY handy, Thanks!
Message 13 of 34
(8,373 Views)
Darren,
could you add the LabVIEW Dialog context as well
(I try debugging some IDE extensions)
Ton
My LabVIEW Ideas
Message 14 of 34
(8,370 Views)
The utility I posted will parse the user's project context(s) and the Main Application Instance.  I cannot post a utility that will go through private contexts as well.
-D
Message 15 of 34
(8,366 Views)
See my post if you just want to change a modal dialog back to default - rather than abort.... I was inspired by this idea.
here
Message 16 of 34
(8,151 Views)
HI
        Thanks for the VI.I have been to the situtions many times to end Labview .exe process. Its very useful and helps a lot!!!!!!!
Message 17 of 34
(8,139 Views)
We appreciate for the efforts on "Abort VI.vi", recently I faced a problem where the "Statechart - Edit Triggers and Groups" window stops working and we could not close VI's. The alternative is to end the task from windows.The Abort VI.vi also could not stop this.
Manish Soni
Message 18 of 34
(7,975 Views)
Manish Soni
If you can reproduce this problem, please let us know. We would be eager to investigate it.
Message 19 of 34
(7,957 Views)
Here is an unlocked version that only searches the current application instance..  I believe it was created by Dan Gilmore and offered on info-labview.  This version will search for all the modal vis and give a menu to close.
I always keep a version in my Dock to get out of self inflicted problems!!
Enjoy, and modify away.
-Scott
 Stupid Freaking Lithium, doesn't allow adding VIs as attachments.  Sheesh.
Here it is as a zip file.  I hear that works sometimes.
Message Edited by sth on 02-16-2009 03:40 PM
LabVIEW ChampionLabVIEW Channel Wires
Message 20 of 34
(7,658 Views)
