05-13-2016 08:29 AM
I need the output from my DAQ assistant to be the input in a formula node. But I can not do it since the terminals are different; dynamic data vs double [64-bit real (~15 digit precision)]. Is there a way in which I can use this dynamic data in a formula node?
解決済! 解決策の投稿を見る。
05-13-2016 08:36 AM
Look in the express palette under signal manipulation for another express VI called "From DDT".
