Create a linear relationship
I have a voltage input on my DAQ device from a volume sensor, and want to link this to the actual volume. Is there an easy way in which I can say that 0 Volt should be equal to a volume of 0 liter and 1.5 Volt should equal 20 liter and have a linear relation for the values inbetween?
(3,442 Views)
Accepted by topic author Allard171
(3,433 Views)
Hi Allard,
apart from DAQmx scales you could use a simple equation like
   flow := 20/1.5 * voltage
Seems easy to implement…
(3,408 Views)
