07-04-2016 10:50 AM
I've created an application which uses elements of the DSC Module that require the runtime licence.
The application has been created in LabVIEW DSC 2014 SP1.
I have purchased a runtime licence (which arrived on a seperate DVD) that has the following printed on the front:
'LabVIEW 2015 DSC Run-time System'
Which when installed, appears as 'LabVIEW 2015 DSC RTS'
Does anyone know if this is correct? I've read that the DSC Module and DSC Runtime versions have to match exactly (see link below) and it appears that when it is installed the things that should work (e.g. shared variable change events) do not work.
http://digital.ni.com/public.nsf/allkb/08CD7233F63B133086257B6A003F18DB
Any advice/experience would be greatly received as I'm struggling to get my application deployed (and it's now late!)
07-04-2016 12:44 PM
Call your local NI sales rep and ask if they can get you a disc for DSC RTS 2014 SP1.
