DSC - Event triggering for Single Process Shared Variables
I understand how to set up a Value Change Notification for Network Published Shared Variables so that an event will trigger when that particular Shared Variable changes. However, I can't figure out how to do the same for Single Process Shared Variables. Is this even possible? Can someone shine a light on this, please?
Thanks in advance.
- James Pham
(3,091 Views)
Accepted by VRspace4
VRspace4,
Hello! It is not possible to enable alarming for Single Process Shared Variables. A workaround to setup a Value Change Notification would be to create a network shared variable that reads from your Single Process Variable, but at that point in time it might be worth just replacing your variable with a networked shared variable.
Ben Sisney
FlexRIO V&V Engineer
(3,068 Views)
