DSC Event Structure Demo.lvproj
Can I use the event structure, as described in the DSC Event Structure Demo.lvproj, to trigger an event on Hi-Hi alarm and not Hi alarm, although the two alarms are enable?
Aviram
(4,323 Views)
Hi Aviram,
You should be able to trigger off the events when both Hi Hi and Hi are enabled.  To do this you would have to monitor the alarm area or url of the Event to determine which alarm triggered the Event.  I have attached and example project that show a possible way to do this.  You will have to change the shared variables to your machine and the case structure inside the Event Structure but it should work for you as well.
Looking to help,
Steve B.
(4,293 Views)
Thanks Bassett it works great
Aviram
(4,223 Views)
