DSC: Archive DataSets Programmatically
Does anyone know of a way to programmatically archive the DataSets created by DSC (8.6)?  The Archive Traces VI works fine for the traces, but the DataSets do not show up in the archived database when using the Historical Viewer or when queried using the List DataSets VI.  I can do it manually by selecting the DataSet section of the Citadel DB in MAX and right click to start the archive wizard, but I'd rather have it done automatically when my client stops a run.
Don
(3,940 Views)
Did you ever get this figured out?  I was told that it can't be done - something I'd rather not believe.
(3,605 Views)
No, I haven't found a solution to archiving the DataSets.  My client occassionally does this manually but it sure would be nice to do it automatically after each run.
(3,594 Views)
Unfortunately this is not possible to do programmatically using LabVIEW DSC.  However, I would highly recommend submitting this to the NI Product Suggestion Center or the LabVIEW Idea Exchange.
(3,581 Views)
David - Thanks for the reply.  I put this in as a Product Suggestion.
(3,573 Views)
