DMM USB-4065
I need some help. I have a NI DMM USB-4065. I have installed the drivers but none of the associated VIs show up under the function pallate's measurements menu. I can not figure out what is wrong. The device shows up under MAX  as working properly and I can access the soft front panel. Any suggestions?
(2,953 Views)
What version of LabVIEW are you using?  What version of NI-DMM are you using?  What version of MAX are you using?  What was the order of installation of these tools?  Was LabVIEW installed after NI-DMM?  If so then perform a re-install of the NI-DMM.
(2,937 Views)
