DMA FIFO Host to Target FPGA
Hello every
I need a DMA FIFO Host to Target FPGA for my projet, I found few examples. does someone have some ideas how to manage the FIFO considering the following issues:
1. For the Host, How to avoid overflow? is thers a VI which can do this?
2. For the Target FPGA, how to avoid underflow?
3. for FPGA, is there any strategy allowing the FPGA to process data in the FIFO at a maxium speed.
4. If the Host is offline, How should the Target FPGA react?
5. If the Target FPGA is offline, How should the Host react?
Thanks in advance
Junli
(3,695 Views)
Junli,
Examples are a good way to understand how to  implement something in LabVIEW.  If you have more in depth questions about best practices for embedded development, I would suggest taking a look at the High-Performance FPGA Developer's Guide and the Compact RIO Developer's Guide.
http://download.ni.com/pub/gdc/tut/labview_high-perf_fpga_v1.1.pdf
http://www.ni.com/pdf/products/us/fullcriodevguide.pdf
The first will answer some of the questions you have about throughput, underflow, and overflow while the second will help with the higher level questions such as, "How should I react?".
(3,667 Views)
