DMA FIFO Host RT to FPGA
Hello everyone,
I need a DMA FIFO host to target FPGA between a PXI-8106 and a PXI-7852R, I am working under Labview 14.0.1
I need to know the available spaces before writing in the FIFO to avoid overflow, but I can't find a VI which can do this, the only way I know to get the available spaces in the FIFO is creating a invoke method <write>, but that means I have to write date before knowing the available spaces.
Then I tried a another VI, <FIFO.Acquire Write Region (Invoke Method)>, but I got a error:
L'erreur -63193 s'est produite à : Invoke Method: FIFO.Acquire Write Region in cerclefifo v10 invoke referencev2.vi
Raisons possibles :
NI-RIO: (Hex 0xFFFF0927) The requested feature is not supported.
I think that means my embedded controler is not supported by FIFO.Acquire Write Region (Invoke Method).
Do you hace some ideas how to solve this problem?  Thanks a lot.
Message 1 of 9
(4,019 Views)
Hi Junli,
You can actually do a zero element write, which will return the number of empty elements in the DMA FIFO buffer. We document that here, http://digital.ni.com/public.nsf/allkb/583DDFF1829F51C1862575AA007AC792, for the read case. I did a quick search and couldn't actually find a document that covers the write case, but I'll update if I do.
Sebastian
Message 2 of 9
(4,012 Views)
Hi, Sebastian
The link you posted isn't accessible now, can you check it please?
speleato a écrit :
Hi Junli,
Sebastian
Message 3 of 9
(3,975 Views)
The error is due to the comma at the end
Paolo_P
Certified TestStand Architect
Certified LabVIEW Architect
National Instruments France
Message 4 of 9
(3,955 Views)
Message 5 of 9
(3,929 Views)
Thanks, everyone, for a FIFO DMA Host to target, there are few examples, I will try to write a empty array in order to query the space avaible in the FIFO on the host side.
Message 6 of 9
(3,915 Views)
This is my VI on the Host.
I use a while loop to quiry the space avaible in the FIFO until at least half of the FIFO is empty, then I write date into the FIFO
Message 7 of 9
(3,913 Views)
Message 8 of 9
(3,911 Views)
Hey Junli,
That looks like the right idea, did this sovle your problem?
One thing I noticed is that the loop timer is outside of the polling while loop, so it's not actualy controlling the polling rate. I think you'll want to move it inside the loop or delete it if your intent is to run the polling loop as fast as possible.
Sebastian
Message 9 of 9
(3,900 Views)
