I tried to run test created with lab view with external tool.
This tool load dll and call execution function.
I created a dll from the Labview test (I used simple function for test that only extract numbers) and I used __stdcall
when I use this dll from an executable It works fine. (My application call a dll, and the dll call to the dll created from labview)
however when I use it from my dll it get stuck
I tried to load the dll dynamically with loadLibrary() and It works fine only for the first time (It gets stuck when I called it again)
I found that if I call it from the same thread it works fine, but if I call it from two different threads (the second call is long after the first call has finished, so there is no race condition) It gets stuck from the second thread.
I used visual studio to see where the call get stuck, and it is in lvrt.dll
Does anyone know what can I do to solve this problem.
