DDC_GetFilePropertyNames crashes MATLAB
Whenever I use this function in MATLAB, it crashes with a segmentation fault error. There was already a thread about it over a year ago (http://forums.ni.com/ni/board/message?board.id=170&thread.id=289453&view=by_date_ascending&page=2|). Is this problem fixed by now?
I am using the following code:
           ppropnames=libpointer('stringPtrPtr',repmat(cellstr(repmat(',',1,255)),1,pnumprops.Value));
           err = calllib('nilibddc','DDC_GetFilePropertyNames',file_handle,ppropnames,pnumprops.Value);
I have tried other alternatives for declaring pointers, but none of them seem to work.
(3,642 Views)
(3,638 Views)
Yes that examples works great, but it doesn't use the function I mentioned. I think this error occurs with any function that returns an array of strings (file, goup, and channel property names).
(3,624 Views)
I am having similar issues returning to a stringPtrPtr. Has a workaround or fix been found for this problem?
(3,347 Views)
Hello jyan2
Can you please describe your problem in more detail so I can better address this issue?  Is there an error code or pop-up generated when MATLAB crashes?  Thank you very much!
Sincerely,
Greg S.
(3,329 Views)
