10-07-2005 09:09 AM
10-11-2005 03:51 AM - edited 10-11-2005 03:51 AM
Message Edited by Norbert B on 10-11-2005 03:52 AM
10-12-2005 10:24 AM
Nobert B
Thanks for the information and the link it was very useful and solved the problem for acquiring a 1Hz signal, however, I am now having other problems that I would appreciate you helping me with. I am still using the "ContAcq&SelectableSave" VI but this time I want to acquire a slowly changing DC signal (output of a thermocouple).
I only want to sample the signal once every 5 seconds to reduce the memory size of the saved data. Is this possible with this VI because the "AI Start" Sub VI's scan rate is in scans/sec?
Before trying to sample every 5 seconds I tried sampling at 1Hz but this too gave me problems as the DC signal I acquired was displayed as 3.8 Volts when the supply was displaying 2 Volts.
cheers
Paul
10-12-2005 11:55 AM
10-13-2005 01:52 AM
