DAQmx version conflict preventing deployment
Hi all,
After installing LV2010 on both my dev machine and my RT target (rt desktop running Pharlap), I am unable to deploy DAQmx tasks to the target.  The error message suggests that the deployment problem is related to a daqmx version conflict between the two systems, but looking at the software lists in Measurement and Automation Explorer (v4.7) both show components for DAQmx 9.5.1.  I've reinstalled the daqmx components on both systems and have not gotten any different behavior.  Anyone else having this problem or know of anything else to try?
tHa
CLAD
(2,575 Views)
In grasping at straws I also noticed that the entries visible under the Software tree in MAX Explorer do not match those that appear in the dialog box when I select "Add/Remove" software.  Maybe my system is using the wrong version of daqmx when it tries to deploy?
I've also been able to successfully run the tasks from the Explorer window.
CLAD
(2,563 Views)
Hi testingHotAir,
Can you double check what version of DAQmx you have in Measurement & Automation Explorer under the software tab. Also, what DAQmx version is listed when you go to add or remove programs? The reason I ask is because the latest DAQmx drivers that are out are 9.2.3 so it should not list DAQmx 9.5.1 under MAX. If it does please attach a screenshot.
<Brian Aswege | Applications Engineering | National Instruments>
(2,543 Views)
