DAQmx subVIs missing from exe application
Yessir, I read those same limitations yesterday, but the message I received this morning was a popup specifically triggered by attempting to edit the DAQ assistant from within the code.  It should be noted that I can build an executable, but doing so results in the problem of all subVIs related to my DAQ assistants being omitted (which is consistent with the popup message discussing DAQ limitations imposed on non-licensed application building software).
I will keep you posted, thanks again!
Message 11 of 12
(450 Views)
Accepted by topic author SteveRusk
FYI:
I recompiled the executable using a fully-licensed Application Builder and it resolved the problem.
Turns out: DAQ Assistant express VIs are not supported by unlicensed application builders.
Thank you all for your help!
Message 12 of 12
(429 Views)
