DAQmx: stop a task during finite samples data generation
Dear all,
I'm generating data on an analog output.I create a waveform and then the data on the analog output, start the task and Wait until the generation is completed.
The problem is that I need an emergency stop if, for example, I need to stop the generation of millions of samples if my waveform is wrong or if Something appends outside.
Could you help me please?
Sébastien
(2,218 Views)
Well, if "Wait Until Done" is a problem, don't use it.  Instead you could use the query "Is Task Done" in a loop, preferably with idling delay of maybe 25-100 msec.   Then you can terminate the loop on either the done boolean output or whatever your "emergency stop" condition might be.
-Kevin P
(2,188 Views)
